ethanol vs non-ethanol performance?
Is there any difference in performance between the fuels on stock or near stock engines? Where I live/boat only have 10% other than driving miles and paying $4+/gal vs about $2.50 for 87 w/ethanol octane? Local on water gas advertises ethanol treated... whatever that means. I have 496HO. Local performance mod on 2 700sci and end result was 12+mph gain on a 42ft boat and it's tuned to run 87 and now runs 105+
thanks |
If the octane rating is the same there are no advantages. Now if you are talking about E85 that's a different story. Biggest issue is Ethanol loves to suck water and can corrode parts not designed for Ethanol. I have a 1998 and I re-plumbed everything because I run 93 octane pump gas with 10% ethanol. I also use additives to keep it stable.
Theoretically you could tune a little leaner on pure gas for a little fuel economy gain.
The 10% ethanol mix will have a slight advantage of cooling the intake charge.
I built 9.8/1 540ci cigarette boat engines in 2006 when E10 first appeared in our area. Had the engines tuned while fully dressed on a dyno. Got them in the boat but had several small problems and ended up flying the guy who tuned it to come run the boat. We had to retard the timing 2 degrees to make them "happy". The tuner guy had never seen E10 at that time and thought I had bad gas.....turns out it's just the difference in E10 vs pure gas. I recall hearing somewhere later that E10 has 3.5% less energy that pure gas. I do know my cars fuel mileage dropped slightly when we made the change.
As for stock engines????? I doubt it makes as much difference as it did in that boat. |
In hot weather, E10 will be more likely to give vapor lock problems than straight gas. The vapor point temperatures are about 20 degrees apart.
If your engines are circa pre-ethanol the performance gain by using non-ethanol in them will be not shredding the fuel system to pieces with ethanol alcohol content.
| All times are GMT -5. The time now is 07:00 AM. |
