Originally Posted by JohanSweden
(Post 4760820)
Thanks. Must love carb engines - as you say, easy to work on.
Whats your thoughts about the Merc 540 Bulldog with procharger, instead of HP500, I just mentioned thats for sale? |
Has anyone taken a SCX and had it REM polished and cyro treated?
Or do they come that way? just curious. |
My thought is that if they are that good to start, wouldn't this process make them even better?
(Post 4760820)
(Post 4760830)
that will be a drive breaker for sure, unless its a SCX
Originally Posted by Griff
(Post 4760871)
Will need high octane fuel. Less longevity, more potential for failures and will push your drive beyond its limits.
Maybe he was lucky. Here in Sweden we have 95 octane gas as standard, and also 98 high octane so that eint no problem if running with the 98 octane. |
Is there any calculation on what speed I can expect with procharged 540 bulldog 770hp?
Now I have top speed at 52 mph @ 4750rpm with my 425hp merc 496. Someone said like 25-30hp is like 1-2mph gain. Would be nice to get some higher cruising speed. |
(Post 4761932)
(Post 4760887)
Thanks for your advice guys, maybe the XR will handle it but eventually not the X upper.. hmm. The 540 has ben running with XR setup in many years without drive failure.
Maybe he was lucky. Here in Sweden we have 95 octane gas as standard, and also 98 high octane so that eint no problem if running with the 98 octane. 95 EU = 90 US and 98 EU = 93 US |
(Post 4761932)
(Post 4761989)
Keep in mind that European octane ratings are calculated differently from American octane ratings.
(Post 4761990)
Approx 15hp for every 1 mph gain for where you are at, but its not linear. If you started at 75mph, it might take 25 hp to gain 1mph
| All times are GMT -5. The time now is 12:23 PM. |
