Bravo I W/2 speed prop vs Bravo III
Hi all
First post. Currently have 24' Caravelle BR with a 496 mag and 2 speed prop (made by Aerostar, might be out of business now). Starts @ 17" pitch and switches to 23. Looking at a 29' Baja with a 496 HO and Bravo III. Unknown props on BIII at this time. But wondering if it is worth the swap to keep my 2 speed prop. Both drives are from 2001, if that matters at all. Thanks in advance |
made by Aerostar, might be out of business now |
The Bravo III is a duo prop that requires special props, in other words the answer is no.
You’d have to swap lowers or find a used Bravo I lower to use your existing prop and even then you’d probably discover it isn’t worth a sh!t on that heavy Outlaw. You’ll appreciate the Bravo III on a single engine 29 Outlaw especially around the docks.
Originally Posted by AllDodge
(Post 4758138)
This should provide some insight to the prop. If they were any good more would use them
(essentially propped about the same pitch/RPM range) on a 292 islander with a 496 HO?
Originally Posted by ThisIsLivin
(Post 4758216)
Originally Posted by Knot 4 Me
(Post 4758218)
I guess that is heavy in the perf boat realm, but seems light compared to many other 29' BR's (but most are twins, so hard to make a direct comparison). |
If your looking for best 0-30 then stick with the BIII. It has better bite out of the hole. I run a 30P on a BI and when I'm running light I break loose real easy out of the hole.
(Post 4759202)
Will try to find one that does have the BIII in the future. |
The thing to know is that the BIII is good to about 60. If you want to go faster you will need to go with the BI. The BIII is much better for moving heavier boats, economy and slow speed maneuvering.
The thing to know is that the BIII is good to about 60. |
(Post 4759659)
Member NoCoast would differ with this
| All times are GMT -5. The time now is 12:11 PM. |
