-   -   Has anyone adapted a bravo to a OMC 460 ford? (https://www.offshoreonly.com/forums/general-q/368701-has-anyone-adapted-bravo-omc-460-ford.html)
SB 09-30-2020 11:21 AM
Originally Posted by Twin O/B Sonic (Post 4759443)
I thought I saw that someone made a kit to do that?
I believe SEI has one that convert to an Alpha GenII. Could be bad memory, you’d have to double check.
Baja226sport 10-01-2020 06:27 AM
Originally Posted by Unlimited jd (Post 4759519)
The spacing from transom to block bellhousing is different. Not sure if the height is the same either. Haven’t done the ford swap, but did do a sbc omc to bravo. Had to change it all.
I did an omc to bravo swap on a chris craft 245 limited last year and it was all literally plug and play. I didn't have to move anything or even drill a hole. I was very surprised at the ease of doing the whole job. That was big block chevy application though.
Baja226sport 10-01-2020 06:28 AM
Yes, they do make a retrofit bell housing. But that is cobra to alpha. This is King cobra being changed to bravo.
Baja226sport 10-01-2020 06:37 AM
One thing I have found out that I guess is a good thing, is that the yoke that goes into the coupler is 100% the exact same part for OMC and Bravo so that will at least not be an issue.
Unlimited jd 10-01-2020 07:43 AM
What if you use the omc inner transom plate and bell housing with the bravo transom assembly?
xlint89 10-04-2020 02:26 PM
Saw your post and just came across this
https://www.sterndrives.com/omc_to_mercruiser.html
obnoxus 10-04-2020 03:38 PM
Yes, I have done this swap using a donor boat. That is what you need to do, reusing the old inner plate, It bolts up fine. I believe they were both1990 era boats. I didn't have a bravo bellhousing to use. I had to swap controls also FYI.
