Stainless marine exhaust pipe plugs
Best place to get the plugs needed to replace one of these elbows
https://cimg2.ibsrv.net/gimg/www.off...7654c3b4b.jpeg |
Try Jerry @ Stainless, the plugs you need have Anodes on them to help with electrolysis.
Brass pipe plug from the hardware store
Originally Posted by Griff
(Post 4761175)
(Post 4761175)
No issue with Aluminum to Brass (elbow) No issue with Stainless to Aluminum (also has gasket) Is an issue with Cast iron to Aluminum but there is a gasket between the two https://cimg8.ibsrv.net/gimg/www.off...20baf64350.png |
Like Griff said , I use a brass plug , or you wanna get fancy get a 3/4" anode and cut the anode short if it`s salt water .. I did that too and on my intercoolers
Originally Posted by GLENAMY 242SS
(Post 4761199)
You have Aluminum manifolds bolted to iron heads and stainless risers, I personally would go with the ones with anodes. Your boat, your money.
mcmaster carr is a good source for hardware.
