-   -   removing a 12" ext box (https://www.offshoreonly.com/forums/general-q/36962-removing-12-ext-box.html)
rssteiny 11-14-2002 06:33 PM
i have a 1998 25 active thunder w/ 500hp and a stellings 12" ext box. the boat porposis bad, i was told the 25 thunder does not need a ext box to short of boat. my question what to do to remove the box. i have ext steering. any help would be great.
also will be selling the box cheap.
cobra marty 11-14-2002 07:48 PM
I would be interested. Where are you in PA?
crmax 11-14-2002 09:40 PM
Im looking for a box also, I could give you a hand doing the switch let me know
puder 11-15-2002 02:10 AM
is it a nuetral box or does it raise your w dim??? I might be interested.
mcollinstn 11-15-2002 10:23 AM
Stelling has 3 holes to use - plus 1, neutral, and minus 1 - all with the motor in the stock location.
Somebody once told me that you can raise the motor an inch and then use the plus 1 holes tfor a total of plus 2. You can't go higher than that using a Stellings without plugging the transom. Again, this is what I have HEARD, no experience with them.
