Prop help
I started a thread a while back regarding prop help with not much or any response. What would put me in the neighborhood of 6,200-6,300 trimmed at WOT?
I’m re powering a 12m ftn. Engines are NA 565’s. Should be close to 740/750 hp at 6,300 + or -. SM3 drives I believe to be 1.5 ratio and Bam cyborg 1350’s which I need to confirm also however pretty certain 1:1. Props that came with boat are clever 15 3/4x27. Previous owner claimed to only run 4,500 with SC 468’s with BM 250’s. I would have guessed to be around 625 however have no way of knowing for certain. Any help would be great. I would like to start somewhere at least somewhat close. Tks John Current props I would have thought should be close however the previous builds/power tell me different. |
17" pitch??? with 625hp and only 4500rpms??? Something is off.
Or 17* rake?? and ?? pitch?? |
Originally Posted by Griff
(Post 4769756)
Typo on original post. Meant 27 not 17. My mistake. Going to edit OP.
Why wouldn't you try what you have and then make the change if necessary,
Originally Posted by GPM
(Post 4769764)
It just seems like there are to many variables at this point. It would be nice if someone like Blades would let you try a few.
Originally Posted by getrdunn
(Post 4769762)
BBlades only check the prop talk section so maybe post there. |
(Post 4770094)
That makes more sense for sure.
(Post 4770096)
I was originally going to however it doesn’t get frequented as much. Think the last post was in October however I’ll try.
| All times are GMT -5. The time now is 03:49 AM. |
