Im running -6 an on both rear sides to a Y connector and dumping a single -6 over board on both engines.
Originally Posted by abones
(Post 4770612)
I might suggest dumping both rears of the intake directly overboard with AN -8s all independent of each other, I did this on my engines it helps at sustained higher RPM runs.
Im probably over thinking but better than under I guess. Lol |
Thanks for all the help Jason. I realize every platform will alter and have to adjust accordingly however that’s a good baseline to start. I remember seeing those restricters you posted. Pretty slick and easily adjustable or replaceable.
One thing I’m curious of is what your doing for a t-stat if any. I would assume you are and drilled holes but your advice on that would be helpful. I’m really curious as the size stricter you used for the bypass. Header temps ok prior to stat opening? Again that’s if your using them. Again thanks for your time and help. I really enjoy experimenting and ongoing look for ways to improve however that’s a great place to start and save me some time. Plus good info for others. That must have been some chitty days when the valves said good by. Dammm. |
Originally Posted by TomZ
(Post 4770710)
Does any of this really change with closed cooling? Or are the issues more prevalent when using a crossover?
More non closed cooling related. Not sure if there’s any improvements to make on closed cooling. Probably though. |
Jason did you have any comparison from std firing order vs the 4/7-2/3 swap. That would be real interesting to know also.
Originally Posted by getrdunn
(Post 4770718)
I would agree independently to avoid any transfer. I was trying to eliminate the amount of dumps however as Rookie mentioned utilizing the exhaust and that actually may serve two purposes (possibly). Just thinking the exhaust might help pull or suck the water through.
Thanks and yes I’m finally on the way to getting in the water. Long project. Business put most on hold. I have dry Stellings to the tip so I’ll have to check that out but certain I will have options. Btw I still need to get john sr on your boat. He’s 80 now even though one would never know it however I wanna get him on the water over 100 mph. 😎
I have 2 -6AN lines coming off my intake.
Thats how it`s always been . I grab water temp back there too. I don`t know what it helps or doesn`t lol https://cimg3.ibsrv.net/gimg/www.off...73f7be0ba2.jpg https://cimg5.ibsrv.net/gimg/www.off...560851df5b.jpg |
(Post 4770721)
(Post 4770723)
https://cimg9.ibsrv.net/gimg/www.off...e189d35a35.jpg https://cimg0.ibsrv.net/gimg/www.off...b9269d0af0.jpg https://cimg2.ibsrv.net/gimg/www.off...39ef9aa48d.jpg |
Getrdun - if you use tstats you’ll have to get tstat spacer with that intake or mill the divider i guess
| All times are GMT -5. The time now is 05:21 PM. |
