HP 500 Blue Paint
So I am refreshing both my engines,, I need an exact color match for HP 500 Blue paint,,does anyone have a paint code they have actually used that is right on to match the Merc. Blue.
This has been discussed many times,,I would like an exact color match if possible. Thanks |
Just a thought. Take a chip to your local automotive paint supply. They can put it in a scanner and give you an exact color match. Most can even put it in spray cans for you.
Thanks Smitty,, I may need to do just that.
there's probably 20 threads on here about merc blue paint, use the search button
I found these in a old thread.
The dupont b8110a (old stock#) = DPC# 15663 (Color Perm Code AJ935) This color is found on Chevrolet 1981 (paint code 20) and Pontiac 1981 (paint code 7204) the name of the color is BRT BLUE. this is to mix 48 oz imron (2 qts) of the Chevrolet 1981 paint code 20 531U LS BLACK 40.6 521U ALUM 100.3 565U RED 357.9 559U BLUE 731.2 572U CLEAR 1053.8 570U LO VOC BINDER 1381.9 8585S REDUCER 1409.0 https://www.offshoreonly.com/forums/...-13-06-002.jpg |
Thanks, I will try this since I cannot find any spray cans
Originally Posted by 253
(Post 4770985)
https://www.offshoreonly.com/forums/...ng-engine.html . https://cimg4.ibsrv.net/gimg/www.off...3036071257.jpg |
Hey Mike, I found the GM code 20 paint at the advance auto parts store in evansville in a spray can when i did someone's engine
Thanks Joe I'll check on that.
I had some of the b8110a mixed up and wasn’t 100% satisfied as it just didn’t seem to be the same but I didn’t have an exact side to side comparison. Next batch I had them add a touch more silver in the mix and turned out great. It at least looked much closer the merc blue powder coat I was using on same project.
