How to delete the trim sender wiring thru a Bravo transom assembly & seal the hole?
I am rebuilding my Bravo transom assemblies and I have them all apart for paint. I have mechanical trim indicator cables on my boat but the transom assemblies have the standard indicator wiring in place. Is there a way to remove the wiring and seal the hole that would be left by removing the wiring/rubber plug that’s in there now? Thanks
There might be a plug but it would be easy to just cut the wires and leave the original plug. I would leave maybe an inch on the outside
if everything is off the boat,have the hole welded up.
Originally Posted by AllDodge
(Post 4776697)
Originally Posted by sutphen 30
(Post 4776703)
Thanks for the reply. I have one assembled already so that would cause some extra work but it’s definitely a good idea. |
Originally Posted by Steve888
(Post 4776752)
19-861492 trim sender hole plug |
Originally Posted by motor
(Post 4776840)
Thanks! |
| All times are GMT -5. The time now is 09:13 AM. |
