B&M 420 blower pulley help needed
anyone familiar with the pulley's on the 420's? a friend just wound up with one he is putting on a 468 BBC with oval port heads and around 9:1 compression and it did not come with the crank pulley. the blower pulley is 5.8" 16 rib and he needs a crank pulley that would put it around 3 or 4 lbs of boost. seems there are only 4 crank pulleys available. anyone have running this blower that knows what to start with on the crank? motor is going in a street car mostly for show and to ensure an adequate amount of rubber is put down to protect the roads.
I would just change it over to 8mm pulleys. they would also look alot better on a street car
https://goodvibesracing.com/Ratio_Charts.htm
I think I have a B&M catalog that has a pulley chart. I'll see if I can scan and post it. I also think I have some 16 rib pulleys. I'll take a look.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
I found the catalog (page attached) but no pulleys.
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
https://teaguecustommarine.com/em001...-16-rib-pulley
Did you by any chance find a top pulley for the B&M 250 blower 16 rib top pulley splined? Do you have any ideas on where to look for this pulley? Thanks for any help you can provide.
