ECM reflash
I’m looking to get my ecm reflashed, the motor is a 502 mag mpi, edelbrock performer rpm heads, 500efi cam, shortened intake runners, hi-tek stainless manifolds, and the bottom end was rebuilt with all new forged pistons,rods,crank. Where would be best to get it reflashed?
Cheers |
where are you located?
Eddie Young, Young Performance Marine.
Padraig |
Originally Posted by sutphen 30
(Post 4778358)
Reflash of the ECM without air fuel ratio (AFR) readings is just a guess. The Merc ECM are programmed on the rich side from the factory, because its safer that way. Putting on higher flow heads and exhaust may not need any improvements. Only way to know is O2 sensors in the exhaust to get the AFR readings
If you get a copy of MEFI Burn then you could reflash it your self if another sends you the file. Might be able to get a file from OBD Diagnostics or Eddie, but as before without testing its all guessing |
Originally Posted by AllDodge
(Post 4778364)
If your ECM is a MEFI, it can be reflashed, even if it has to be wiped and new program reloaded, easy
If its a 555 then harder to do, but can be done, or at least Whipple says they can What do you have? |
(Post 4778375)
Correct the standard file is set for 87
Note, you may know this: the UK octane is straight RON where the USA is RON and MON which is on the anti-knock index. So UK 97 = 91 USA Should not be an issue getting a MEFI-1 done. The 1 isn't even password protected. I have the MEFI Burn software and its easy enough to change the settings or just use it to reflash yourself. Might try what you have and if not doing good enough then see about changing things. Run, stop and check plugs, then run some more. Best to add so O2 sensors and watch |
I was faced with the same scenario and decided to carb my motor. When I get the coin together I will run the Holley hp setup. It simply didn’t make sense to invest in 35 year old parts.
If the ECM has not been re tuned, I can't believe the engine has not melted a piston.
Your best bet for somebody to tune it by mail is probably Eddie at Young Performance or Marc Boos at Precision Marine. |
| All times are GMT -5. The time now is 01:32 PM. |
