Interesting find while measuring pushrod length. >
Old 03-04-2021, 08:02 PM
TomZ's Avatar
Received 1,231 Likes on 686 Posts
Running into guide plate issues. I have Dart adjustable guide plates (recommended by AFR back in the day) but the adjustment nut on the. Ottom limits travel. If it isn’t one thing it’s another, lol. I have some factory Gen VI guide plates that I might give a try.
I think I have the pushrods figured out. Once the guide plates are stable, I’ll mock it back up to see if they’re still coming out the same.
TomZ is offline
Old 03-05-2021, 05:59 AM
I had the same problem. I just put the bolt in with the nut on the top side of the guide plate.
fbc25el is offline
The following 2 users liked this post by fbc25el:
SB (03-05-2021), TomZ (03-05-2021)
Old 03-05-2021, 07:56 AM
TomZ's Avatar
I thought about doing that. I read in another engine building forum that a person with the exact issue replaced the screw with a button-head and flipped it so the nut was on top. I guess he did this so that he could adjust on the engine. It'll just be more of a tedious process.
Problem solved.
I'll mock it up at lunchtime.
TomZ is offline
getrdunn (03-05-2021)
Old 03-05-2021, 06:19 PM
I took my guide plates,cut them in the middle,,adjusted them perfectly,then tig'd them.numbered them and was able to keep them in the same position after a tear down.
sutphen 30 is offline
The following 2 users liked this post by sutphen 30:
Old 03-05-2021, 11:42 PM
TomZ's Avatar
I’ve contemplated welding them but with the way these go together and bend while tightening under the stud, I feel they may crack. I think I’ve got it figured out though. I flipped the screws, aligned each guide plate, and then tightened them up. They were still a pain to align.
TomZ is offline
