-   -   k plane instructions (https://www.offshoreonly.com/forums/general-q/370715-k-plane-instructions.html)
Zinger 03-09-2021 06:23 PM
Does anyone have a manual or instructions on k plane installation or where I can get one.
Jeff
phragle 03-09-2021 06:27 PM
Jeff
What do you need to know?? there is not much to them. Ask away.....
Zinger 03-10-2021 07:14 AM
The mounting height and location along with how thick the transom needs to be and a wiring diagram.
phragle 03-10-2021 08:34 AM
Wiring diagram is the same as trim pumps, blue (sky) up, green (grass down). all transoms should be pretty much the same thickness.
your biggest variable is if you want to mount them horizontal or mount them parallel to the bottom. and that is not really covered in any instructions and is more relative to whatever boat you are putting them on.
And DONT 5200 them on,,,,,,
Griff 03-10-2021 01:15 PM
95% are mounted parallel to the bottom. Mount them 3/4"-1" above the bottom.
Mbam 03-10-2021 03:28 PM
It actually should be opposite on the tabs. The high pressure side = blue = down for tabs
With you on the 5200 however I will say West Marine has a product called Debonder that is magic.
