Tachometer Signal Wire MYSTERY
Man do I have a mystery on my hands, any insight would be appreciated.
Just swapped a carb'd 454 into my 1999 sea ray sundeck 240 - Oh yeah, she rips I'm usually a hot rod/motorcycle guy but being stationed in Florida, I wanted to build a boat for the water and my youtube channel. My ignition coil has 1 purple lead (+) and 2 gray leads (-) The engine would not fire unless I disconnected one of the gray wires on the negative side of the coil (turns out, this was the tachometer signal wire) The engine runs fantastic but as soon as I connect the signal wire - The engine will abruptly shut off. Tach has 12v - new coil - continuity tests on tach and coil wires all good Almost seems like the coil is grounding out through the tachometer. Thanks! |
My thought exactly with the tach having a short or grounding somehow. You said the tach checked out fine though. What happens if you disconnect at the back of tach while leaving both wires on the coil. I never had a tach go bad. Any other wires going to tach. If so possible something else further down the line. Just guessing.
It's for sure a 12 volt coil right! Everything all good at the distributor sounds like. Damm that seems strange. Try the above.
check the wiring and see if you pinched a wire while installing motor..
yes, that can happen. Bad tach’s csn cause misfiring and sometimes no start.
More common is someone installing a new tach but putting wires on in position of old tach, not realizing new tach has posts in different positions. Also I have seen twice, people hooking grey tach wire to ‘ignition’ post of the tach. Ignition is ignition switched power, usually purple wire. Gray tach wire should go to ‘sender’ post. |
Good points. I'm just guessing however I doubt tach was even touched or wired with repower.
Wow wasn’t expecting replies this quick thanks everyone.
regarding a pinched wire - eliminated the potential of this problem by running a wire from the tach all the way to the coil - same problem regarding tach wiring - ordered all new gauges (mercruiser brand) and tach has the same 3 posts as the other labeled - power, ground, and signal i will take a picture when I get home from work - wiring isnt the best I picked this boat up in Panama City for 2300 and did a full resto The best comparison I can make concerning the condition of the boat when I picked it up would be a crack house that’s actually a boat |
That's a new one. 😂 You've definately done your troubleshooting. Ground from tach goes a short distance to ground block under dash correct. Just making sure it's not touching 12 v anywhere.
I know this sounds highly unlikely but did you try another coil. This past summer I chased a small engine issue for what seemed like forever. Somehow the coil checked out good however after replacing problem solved. Mine was intermittent though which I didn't even realize a coil was capable of.
Replaced the coil 3 months ago before I dropped the motor in
could be bad batch though I’ll take some pictures after work - hopefully that helps |
