-   -   Water pressure Sender Location? Whipple Supercharger (https://www.offshoreonly.com/forums/general-q/371237-water-pressure-sender-location-whipple-supercharger.html)
nova2_excalibur 04-18-2021 02:40 PM
Hello,
i have two 377mag Mpi with Whipple Supercharger.
IT works great, but Inhaber a question.
My Water pressure ist not very high. Only 8 Psi at wot.
The Water flow is this:
Water pump-Fuel cooler- t connecter for intercooler- Steering cooler with pressure Sender.
Also a Lot of Water is going to my intercoolers..
Nö i have Seen, that the old 496 have their pressure Sender at the Water Pump. Is this better?
So i can See all the pressure from the pump?
What does you think?
ICDEDPPL 04-18-2021 04:29 PM
Intercoolers should have their own pickups. That also helps with idle so the fuel doen`t fall out of suspension because the intercooler is too cold .
Sounds like you are feeding too much stuff.
Where is your water pickups now? Thru a bravo drive?
Intercooler should have at least 20psi.
nova2_excalibur 04-24-2021 03:32 PM
I have only the Drive Pickup for cooling. Sportmaster Low Walter Pickup.
The Manual from whipple say, i must add a T after the SEA Water Pump for the intercooler. No extra Pickups needed..
Also ist works great, but the pressure ist mit so high.
