Excessive engine speed
I’ve got the alarm excessive engine speed on my Merc 600sci at about 4400rpm, does anyone know what this alarm means?
I’m going to say it’s not sensing being in gear
^^^Agree, Look on the shift plate to see if there is a switch. If there is disconnect it and see if it happens again. Disconnecting it will not set a code or do anything else
Should add; I'm not real familiar with your motor, but none of the Merc's will have any issues doing the same |
| All times are GMT -5. The time now is 09:13 AM. |
