Mine did not have any adapter, and I thought it was just a test install. I wiped the location down with lacquer thinner and scuffed it a little. Put some silicone down and pushed the transducer into it.
Originally Posted by liberator221
(Post 4807683)
Thanks! |
Yes
i guess probably 1/8 - 1/4” |
(Post 4807695)
Yes
Any old Formula (1988 311 SR1) people have a recommended route for the transducer cable...looks like getting under the gloss black dash (near the compass) is a tough act.
Thickness doesn't matter because it will all squeeze out anyway whether thats 1/8inch or 1/2 inch. Just make sure you have thick enough to completely fill all the space between puck and hull and a little extra to make sure. Just a tip - either make a little mound in the middle of the sealant so no air bubbles get trapped, or maybe push the puck in at a slight angle to get all the air out. Push the puck all the way until it touches the hull.
Originally Posted by Cap'm Kurt
(Post 4807734)
| All times are GMT -5. The time now is 05:58 PM. |
