-   -   Mercruiser 496 crank no start (https://www.offshoreonly.com/forums/general-q/371846-mercruiser-496-crank-no-start.html)
Jasbro1968 05-31-2021 01:15 PM
I would like to start out that I'm a new member. I was at a lake this past weekend and I hit a sand bar going around 10 mph and only the lower drive scraped about 6 inches. The prop is fine and the lower is scraped up with some small damage to the edge. When it started to drag i immediately threw it in neutral and turned it off and then trimmed it up. But now it will not start. I bypassed the neutral safety switch and nothing. The motor is a mercruiser 496 with a bravo one x. Any help would be appreciated
SB 05-31-2021 01:32 PM
When you turn key to crank, do you get power to yellow/red wire going to remote solenoid ? If so, power also at yellow/red on same solenoid to starter ?
Jasbro1968 05-31-2021 02:55 PM
Before I crank i have 12.5 on one side of the solenoid. when I crank I'm getting 9.5 volts on the other side. Its cranks fast but I checked for spark and nothing
techman 05-31-2021 03:01 PM
Safety switch/lanyard pulled?
Jasbro1968 05-31-2021 03:07 PM
While cranking im getting 10.8 on the yellow wire on the starter. And I checked the kill switch while I was on the water
Jasbro1968 05-31-2021 03:10 PM
I also bypassed the neutral safety switch and nothing
SB 05-31-2021 03:19 PM
Ok, thanks. You didn't mention it was cranking. Lol. Neutral safety switch effects crank /no crank.
Do uou have soark and fuel psi when cranking ? Does tach go to 400-400 rpm when cranking ?
edit in: i guess i didn’t read the title. Lol. Sorry
Jasbro1968 05-31-2021 03:25 PM
No spark and when cranking tack is slightly lower than 1000 and ill have to get a fuel pressure gauge
Jasbro1968 05-31-2021 08:09 PM
So I have tested the kill switch, neutral safety switch, red circuit breaker, unplugged every connection and checked the harness, checked voltage on the batteries. I'm trying to see if I can get ahold of a scanner. But I'm out of ideas. I've hit big waves that jarred the boat harder than I hit this sandbar
PA.WOODCHUCK 06-01-2021 10:56 AM
My 2002 496HO has 3 relays near ECM which all are same part number. Have U tried swaping them?
