Engine hatch actuator (acculift)
SubscribeI am in need of a replacement actuator motor for my engine hatch. It is original acculift actuator motor model MQ347, serial PV24188Q, dated 1995. The hatch motor is weak and no longer has the power to lift the hatch. It has dc power. Just worn out. I’ve tried to find a replacement online with no luck. I’ve also tried to call Danny (supposedly) of acculift in Michigan, with the number I’ve found through this site. And was unsuccessful. No answer or call backs. Anyone that can help with any direction to go or a compatible replacement motor would be great. Thanks.
AmiableDave
close
- Join DateJul 2017
- LocationBradenton, Fl.
Liked:579 Times in 242 Posts
Do you have the motor in-hand? Take it apart. It may just need a good cleaning and new brushes...
F-2 Speedy
close
- Join DateMay 2012
- LocationMidwest & T-Rock
Liked:3,967 Times in 1,808 Posts
AmiableDave
close
- Join DateJul 2017
I’ve tried many times over the years to get ahold of acculift and QM with zero luck. Acculift are serviceable, but IMO, they aren’t that great and I’d look for a newer aftermarket replacement.
Rookie
close
- Join DateJan 2003
- LocationGrand Rapids, MI
Liked:1,522 Times in 736 Posts
Quote:
Do you have the hatch on relays or just off the switch at the dash? If no relays I would suggest putting them in. They move 3 times faster and have the power. My Scarab deteriorated also and relays fixed the issue.Originally Posted by scooby94
PA.WOODCHUCK
close
- Join DateMay 2018
- LocationWestern Pennsylvanoa
Liked:111 Times in 85 Posts
Have you checked the voltage at lift when running... to rule out voltage drop?
I can take the motor off. I checked voltage with it lifting and had a heavy draw, down to 8.5v. I don’t believe it to be on a relay. But that may help. Anyone have a wiring diagram of a example for one with a relay. I haven’t been able to find a aftermarket replacement motor without having to buy the entire lift assembly for $500.
Rookie
close
- Join DateJan 2003
You can't do it with 1 relay. I use a reversing motor solenoid/relay.
https://www.ebay.com/itm/16490501345...EAAOSwzmRgwLda
PA.WOODCHUCK
close
- Join DateMay 2018
I did this because of same slow issue and I made a wiring diagram for installation. just send email to [email protected]
Cole Hersee Forward & Reverse Relay Module 24452-BX | O'Reilly Auto Pa (oreillyauto.com)
