-   -   Oil pumps… draining and filling oil, priming? (https://www.offshoreonly.com/forums/general-q/372306-oil-pumps%85-draining-filling-oil-priming.html)
Metalguy38 07-02-2021 02:30 PM
I’m tired of messin with my POS west marine special…
I’m slowly getting my new 4500sq ft shop set up, always looking for ways to make maintenance and wrenchin more enjoyable/easier.
Do any of y’all have a proven recommendation for a HD transfer pump? I run SAE50 in my boat motors, 15w40 in several diesel trucks and tractors/machines, also would like to be able to pump 85/120 gear oil into my drives from bottom. I’ll make a carry caddy so it can roll on floor with dump reservoir or detach and set in bilge/cab etc and wire in a switch so it can be turned on or off at use point. Reversible flow would be nice so less hassle from draining to filling.
https://www.enginegearonline.com/1-g...uel-and-water/
something like this^^
I know the engine drain/fill is easily accomplished, it’s the filling of the gear oil in most concerned about.
on a side note… anyone using a pump like this or similar as pre start primer for your engines?
-Bill
