What Gen 496?
How do I determine what Gen my 2002 496 engines are? Serial Numbers are OM348444 and OM348383
Cant seem to find any reference to what Generation they are Thanks, Kevin |
As far as I know, all 496's are a gen VII. What are you trying to accomplish?
Yes all the 8.1/496 from 2001 to the end of production are considered a gen VII (7). There were some slight updates over the years to the fuel system (around 2005 ish), the heat exchanger size, and the exhaust manifolds to mention a few. Yours from 2002 should have the aluminum exhaust manifolds, a 3.5" dia heat exchanger, and the Gen 2 cool fuel system. There were a very few early 2001 496HO engines that had the forged crank made by Kellog. The rest of the engines have a cast crank and non forged rods/pistons. All have smartcraft and can utilize the vessel view technology.
Originally Posted by 87MirageIntruder
(Post 4796262)
That's false advertising Underpsi68! Everyone loves stickers though.
Just want to know for the Cool Fuel issues with the paint flaking off inside the fuel pumps and getting into the injectors. Some were saying it was the later Gens that had this issue, others say it was resolved in later Gens. Dont know where my engines fall in this situation.
Also, good to know if ordering parts. I didnt realize there was a Gen VII of the 496. Thanks for all the info. Kevin |
Technically.
There isn’t a Gen VII of the 496. The 496 is the Gen VII of the big block chevy. |
Originally Posted by underpsi68
(Post 4796266)
Just to correct the above, all 496's do not have smart craft. My 2002 did not even though it had smart craft stickers on it.
From Mercury
"The SmartCraft line of products are applicable to all Mercury/Mariner OptiMax outboard engines starting with Model 2000, and all MerCruiser 8.1 liter engines for Model Year 2001" |
Originally Posted by Indy1K
(Post 4798032)
How would I know if my Cobalt has it or not? I have the stock Faria Beade gauges. COMMANDER version, but no digital output to a network connection, that I know of.
I know it states all 8.1 are Smartcraft. After talking to this very knowledgeable tech, mine was not, nor were the earlier serial numbers. I wanted to connect the engine to my Garmin 740. I was never able to do it. Mine was also a 2002 FWIW. |
Not to confuse the issue, but a 496 is a stroked 60 over 454. Not all 496s have to be Gen 7 motors. It's the first time in the BBC series, since 1965, that a motor is nothing like it's predecessors. No parts swapping with 454s etc. and parts are harder to come by.
Originally Posted by HawkX66
(Post 4798106)
Originally Posted by SB
(Post 4798107)
Did you see the opening post ?
parts are harder to come by |
Originally Posted by techman
(Post 4798115)
Why do you say this? Other than some backorder pandemic related delays, it would seem you can get any part for them. It's hardly a low volume custom engine series.
(Post 4798119)
If you've ever been a gear head you would know where I was coming from. I'm sure you can get any part for them on-line or even from dealers, but it's not like Mk IV or Gen 6 motors. Just about everything is interchangeable besides the crank from 1965-2000. Used blocks are everywhere for relatively reasonable prices and the knowledge base is far greater. I'm not saying a 496 is a bad motor. I wish I had one right now lol My motor is down...
Probably in another couple of years all of the current LS marine engines will start showing their spots and we'll look back and say....those late model 496's were a peach. |
(Post 4797869)
| All times are GMT -5. The time now is 11:44 AM. |
