Gear Oil Leak???
Last year I bought a 2009 Checkmate 270 Convincor with the 496 HO motor. It had only 100 hours on it and is in like new condition. It now has 157 hours and I noticed it uses about a tablespoon or so of gear oil every time I take it out. I don't run it hard and cannot find a leak anywhere including the prop seal. Any ideas? Thanks
The best way to zero in on the problem - if there is one - is to have the drive pressure tested.
Has the gear lube been changed recently?? It often takes several outings to work out every last bit of air.
If you can't detect or see any leaks, its could have a leak at the input shaft seal and the lube will leak into the bellows. |
I changed it at 125 hrs. If it leaks into the bellows, won't it leak into the engine compartment with the motor up? I'll pull the drive this fall and check the bellows anyway. Thanks for the help!
not saying it’s normal but I’ve seen people reporting bravos using oil after 10-15 hours.
I don’t know about a teaspoon every outing but they’ve had to top it after some extended use. with that being said there are only a handful of places it can come from 1. top cap 2. back cap 3. prop shaft 4. between up and lower 5. around carrier If you see nothing in the bilge it’s likely 1-4. |
Originally Posted by Griff
(Post 4798519)
I bought a new 2006 Sea Ray Sundancer with Bravo 3 Drive. After about a year I found a reservoir tank losing oil every time I took it out. NO indication of a prop seal leak and NO indication of water in the oil.
Took the boat into my mechanic and pressure tested the out drive, finding that the prop seal WAS leaking. Come to find out that the Mercruiser inner prop shaft had hardening problems. The shaft was heavily grooved where the seal road. Yet it never showed signs of leakage until it was pressure tested. Sea Ray was balking on the warranty but finally came through. |
Originally Posted by AmiableDave
(Post 4799528)
Took the boat into my mechanic and pressure tested the out drive, finding that the prop seal WAS leaking. Come to find out that the Mercruiser inner prop shaft had hardening problems. The shaft was heavily grooved where the seal road. Yet it never showed signs of leakage until it was pressure tested. Sea Ray was balking on the warranty but finally came through. You bought the Sea Ray which has it's components obligations to warranty (and will replace components ie lights, sink faucets, vents, +++)from it's vendors under warranty in order to expedite the replacement BUT they are also collecting a warranty from the vendors for their product failure) |
| All times are GMT -5. The time now is 02:10 PM. |
