-   -   Mercruiser 7.4 serial numbers? (https://www.offshoreonly.com/forums/general-q/373042-mercruiser-7-4-serial-numbers.html)
JaniH 08-22-2021 08:27 AM
Is there place where i could find out the year model with the serial number? B947354. All i can find is that it is 1988-1991, 7.4l
PA.WOODCHUCK 08-22-2021 11:42 AM
From merc a dealer ran
manufactured 12/23/87
registered 5/4/88
couldn't find anything on HP.
JaniH 08-22-2021 01:03 PM
registered 5/4/88
Thanks alot! Can you see where it is registered the first time? The engine is now in europe. One site claims it is 7.4 magnum 365hp.
PA.WOODCHUCK 08-22-2021 07:27 PM
Originally Posted by janih (Post 4802548)
thanks alot! Can you see where it is registered the first time? The engine is now in europe. One site claims it is 7.4 magnum 365hp.
miami ,fl 33189
outonsafari 08-22-2021 08:56 PM
Pull your valve covers and oil pan, those era/model mercury engines have 4 bolt main, forged rotating assemblies, 990 or 188 rectangle port heads, or they don't and it's just a base model engine.
the earlier 80's engines 370 and 420 had crane gold roller rockers, i don't know if those rockers carried over to the 365 mag tho.
i'll try and find some threads and part look up link.
https://www.perfprotech.com/mercury-...gines#hp-table
same site says no results found for that serial number B947354 or OB947354
https://www.offshoreonly.com/forums/...num-motor.html
https://www.offshoreonly.com/forums/...54-magnum.html
https://www.offshoreonly.com/forums/...mber-info.html
