2nd time here we go again clanking ticking noise after engine shut down
#101
Was a good price.. Jegs makes them...all others were over 400...
thanks
#102
you can use stamped steel roller tip with no clearance issues
#103
No way.. They are the worst. I went thru 2 sets of those.. They burn up....garbage . they are not a roller rocker their stamped steel with a roller tip no difference in the stock stamped steel rocker
#104
if you burnt them up you have an oiling issue
The following 2 users liked this post by F-2 Speedy:
Griff (09-10-2021), liberator221 (09-09-2021)
#105
2 sets on each engine burned up. I contacted Compcams and they told me if you're using a high volume oil pump you cannot use these rockers. If you look at the oil hole on your rockers it's pointing straight up if you look at the oil hole on a regular stamp steel rocker it's pointing to the stud . the reason was with my engine it was shooting over the rocker. And I believe I have Spring pressures opening over 350
#106
#107
2 sets on each engine burned up icon burned up I contacted Compcams and they told me if you're using a high volume oil pump you cannot use these rockers. If you look at the oil hole on your rockers it's pointing straight up if you look at the oil hole on a regular stamp steel rocker it's pointing to the stud . the reason was with my engine it was shooting over the rocker
35fountain (09-09-2021)
#108
This is good to know guys Ive never ran them before but installed them on my 427 Vette engine but have not fired it yet, first set Ive ever bought
SB (09-09-2021)
#109
Happy Labor Day everyone! Check this out......... I cannot believe this!
https://www.youtube.com/watch?v=OotvXO7K_5M
You are on a quest, for sure....good luck and keep us posted! This is one of the strangest things I've ever heard of in many, many years of boating and running high-performance cars...
Baja 252 Islander
Baja 252 Islander
SB (09-09-2021)
#110
35fountain (09-10-2021)
