2nd time here we go again clanking ticking noise after engine shut down
#131
What roller rockers do you recommend
Summit and jegs make their own a little bit more money but I think it's the same thing with a higher price tag.
#132
#133
Scorpion, Crane, Lunati, Howards, Hartland sharp ? there's probably 10 or that will work and good quality
#134
#136
well I think I made the right decision. A lot more than I wanted to spend but at least I know they are quality made. Now for valve covers. I don't think they will fit under a stock cover, but maybe with a spacer?
#137
They have been around for 15yrs or more. Been caught up in fraud cases. Their schit breakes because they don’t give 2 fuks. Not because of a once in a while defect. They slso change names every so many years so people hopefully don’t notice. They are now Soeed Shops Inc (SSI) or some schit like that. First name was Procomp Electronics.
Small example: pull open one of their fake msd boxes (they got in trouble for making box look like msd) and guess what ? A cooy Gm hei module by itself inside.
procomp harmonic bakancers break apart, rockers, etc, etc
Yiu’ve been forewarned enough by me. Do your homework.
#138
Why screw around, go with some Comp Cams shaft mounted rockers!!
https://www.summitracing.com/parts/c...make/chevrolet
Probably will not work with your valve covers though.
#139
#140
Honestly, long slot stamped rockers are entirely adequate for your motor once you get the basics worked out.
But the rockers you bought are great.
And a dial indicator and mag base - yiu don't need a Starrett or Mitutoyo (brand).
Grab these at Harbor Freight.
