Blower shop 250 vs Weiand 256 or ???
Hey there all. I am in desperate need of an intercooler for my motor. Its a 540 with a tbs 250 blower. Teague no longer offers the superchiller and they have no intentions of bringing it back. My question is, does anyone know if the bolt pattern or footprint of the tbs blower is possibly the same as say the weiand 256 that is on the 575sci motors? They still make those. Maybe I could adapt it to work for me possibly. Or does anyone know another source for an intercooler for the tbs 250 blowers? Thanks in advance!
Originally Posted by Tcarp
(Post 4804682)
Pretty small blower for a 540ci engine.
Sell your 250 setup and the upgrade to an 8 or 10-71 will be less than the cost of adding an intercooler and plumbing
Originally Posted by Unlimited jd
(Post 4804695)
Originally Posted by ICDEDPPL
(Post 4804694)
(Post 4804696)
Wouldn't I need an intercooler for the 8-71 then at that point?
A 250 is 250cid, an 871 is 436cid, I would recommend upping the blower size as the others stated above. With the 250 chiller combo you will need to spin it up even higher, just not a great setup.
I talked to The Blower Shop guys today and I also called Teague Marine.
Person from Teague told me that there’s nothing out there that can be adapted to fit the TBS 250. Teague marine was the only company that made these coolers. One thing I DID not ask is if an old B&M intercooler would. Not sure if there’s any difference between those and what Merc used on the 575 and higher SC setups. Honestly, I figured somebody could drill and tap the holes in the correct spot and use some sort of chiller as long as it would seal up halfway decent(?). I just don’t know. Bummer cause I was asking the same question, which was “what could I buy to make it work on my 250.” |
All you need is a really big chunk of aluminum and a mill....Then you can adapt whatever you want.
If you step up to a 6-71, 8-71 or a 10-71 and only plan on 3-5 lbs of boost, no need to run an intercooler.
I had a set of Chiefs built by Tommy years ago and they were 502's with 6-71s no coolers and they made 700 on the dyno and I ran them for 300 trouble free hours before I changed power |
I would think to achieve 3.5 pds of boost in a 540 ci engine with a 250 blower you’d have to spin it much faster. Which in a sense would create more heat than that of the same in a 454. Yes no maybe???
I modified a 250 chiller to fit a 420 pretty easily, just had to drill and tap a couple of holes. If you can find one for a 420 it should work with a little modification
Originally Posted by snapmorgan
(Post 4821200)
i noticed same info searching earlier here: https://www.cpperformance.com/p-8018...tercooler.aspx |
Originally Posted by getrdunn
(Post 4821168)
The blower is not spinning that fast even on a 540ci. The stock 502ci/575Sci runs 4# of boost. |
Originally Posted by Griff
(Post 4821204)
I really don't see the need for a chiller when you are only running 3.5# of boost.
The blower is not spinning that fast even on a 540ci. The stock 502ci/575Sci runs 4# of boost. What would one expect power wise out of a mild comp 540 w/3.5 pds - Just curious. 65 hp? Sounds like what OT is looking for. |
(Post 4821209)
A 575SCi is just a 502 with 7.5 compression and a 240 duration ,560 lift flat tappet cam. Without the 4# of boost, it prob would not make more than 450hp |
I had the 256 with Whipple chillers. Engine rebuilt with 871’s and no chillers. That in my opinion is the way to go.
Sounds like a good way to go!!! 👍👍👍
Whipple used to sell an intercooler for TBS 250. I looked into it a few years ago for my setup. It wasn't cheap though. I think it was in the 3k range?
I don't remember what I paid. I do believe it was around $3,000.00. Current price is $6,595.00.
I found the old email from Whipple.
Part# WC-9030B Standard deck in black. WC-9032B Tall deck in black. Price was $3995.00 back in 2017. Guessing lose the B in the part number for polished. If the price is now $6595.00 I'd go with a bigger blower instead! Has to be the cheaper route! |
Blower
| All times are GMT -5. The time now is 08:09 PM. |
