Warm water in bilge >
Warm water in bilge
Warm water in bilge
Old 09-20-2021, 12:09 PM
Crud in the water end of the oil cooler causing the pressure to rise and push water past a hose clamp?
fbc25el is offline
Old 09-20-2021, 01:02 PM
Received 1,619 Likes on 795 Posts
I would lay some sheets of cardboard on the bilge floor and do a very brief run to get the water pressure up. The cardboard will make it easy to see where the water is coming from.
Griff is offline
The following 2 users liked this post by Griff:
Helmwurst (09-20-2021), kvogt (09-20-2021)
Old 09-20-2021, 01:05 PM
That's a good idea.
nygman11 is offline
Old 09-20-2021, 01:08 PM
Try thread sealant on block drains, check the intake gasket at the rear, check the weep hole on the circulation pumps. Buy a bore scope camera from Harbor Freight to inspect areas you can't see easily.
ThisIsLivin is offline
Old 09-20-2021, 01:56 PM
Camera ordered will be in tomorrow. I will check all of the areas you and the other posts mentioned. Last but not least will be the cardboard run.
nygman11 is offline
Old 09-20-2021, 01:58 PM
Originally Posted by Helmwurst
Check you exhaust hoses and clamps. Sometime they will leak at higher pressure/RPM's. Seen it more than one. Had the same symptoms on my own boat, chased that water in the bilge issue. Took a mirror and went around all the exhaust hoses and clamps. One was not even all the way around. loosened it up and moved it even, water leak gone. Rechecked a couple of weeks later and it was about 1 turn loose. .
I just put EMI manifolds on mine, had a small leak when fired up on hose. Hose clamp wasn't loose either. The hose clamp had sliced the hose, when I wiggled hose leak increased. Trimmed an inch off and re-clamped. Issue solved.
Id go through an wiggle/check every hose connection. Likely a similar issue, especially if warm water.
Gimme Fuel is offline
The following 2 users liked this post by Gimme Fuel:
GailWins (10-01-2021), SB (09-20-2021)
Old 09-20-2021, 03:01 PM
If you have sea strainer try putting RED food color inside the sea strainer.
That will show you where it it ........
floridaoutlaw is offline
Old 09-20-2021, 05:02 PM
Originally Posted by nygman11
If you are asking about the ones in the exhaust manifolds I just changed the exhaust system last year to stainless marine thinking the stock cast iron manifolds had a crack in them but I still have the same amount of water coming in. Is there other drains I am not seeing?
Being not familiar with that engine I just was going by what a 454 has, which is a drain petcock on each side of the block plus one for each side of the exhaust, sometimes an oil cooler or power steering cooler, Cool Fuel, etc.
Baja 252 Islander
bajaman is offline
Old 09-21-2021, 12:00 PM
TomZ's Avatar
Received 1,126 Likes on 633 Posts
As others have mentioned, look at the block. High water pressure on a 502 can cause the head gaskets to leak to the of the block. My 502s also pegged the water pressure meter at higher rpm and speed.
Hoping it's just a hose leaking. Let us know what you find.
TomZ is offline
Old 09-21-2021, 01:27 PM
Do you mean to the back of the block?
nygman11 is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell or Share My Personal Information -
Copyright © 2023 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
