502 Mag Mpi repair after water in oil
1 Post
Hi all, long time researcher first time to post. 1997 Hallett party cat deck boat, 850 original hours, head refresh around 400HR, briefly in brackish water, but in fresh water for 4 years i owned it.
Over the holiday i noticed milkshaked oil coming out of my dipstick. I sucked the oil out, replaced oil and ran for a minute before starting disassembly. I found the left intake gasket was out of position and someone just made new holes. There is pretty heavy corrosion at this area. I noticed the epoxy coating on underside of the intake was missing in area of the water passage. Should i assume the water made its way there and blew it off? Is it possible to get the intake weld repaired and machined?
I got the left head off before having to go back to work out of town. I will complete disassembly next week. The head gasket did look like it was starting to leak. The head looked good, no corrosion, minimal carbon. Due to the age of my motor, should i look at new heads, or can you recommend a shop in the Atlanta area to go to?
Do you have any suggestions past getting the heads off for a look and fixing or replacing the intake?
Make sure to not alter too much on that engine. You'll need to remap the ECM if it goes too far out of specs. Might be better to have the existing heads checked for cracks, replace the seats, and do a rebuild. Less complicated. Just a thought.
1 Post
Thanks TomZ. Taking the right head off was a challenge. one of the bolts had head corrosion and took a bit to extract. Both heads are now off. The cylinders look good and i sprayed a gallon of mystery oil in cylinders and lifters.
I'm back working out of town, so will have time to call Ron and do more research on heads and what pushes you into remapping..... And find a 454/502 MPI intake.
Sounds like your heads were good so re-use them. Have a valve job done though. Usually valves are most often the issue with compression on I/O motors.
On the intake, if not too wide spread corrosion, say just around the water port, do a good job of cleaning the area and use JB Weld. Level it good though.
1 Post
I could also use injectors, i have no idea how old mine are.
You'll need to verify the ECM generation. MEFI-3 has the connection points on the face of the unit and is more square looking than the MEFI-1 (connection point are forward and aft). The MEFI-3 wasn't used until 1998 but anything is possible. The injectors and intake are different between the two (MEFI-1 uses a long injector and the manifold is drilled accordingly).
You may be able to have the manifold repaired. It shouldn't be too difficult unless the aluminum has become porous.
