-   -   what size k planes??? (https://www.offshoreonly.com/forums/general-q/37354-what-size-k-planes.html)
ROUGH WATER 11-20-2002 07:39 PM
IS THERE A FORMULA OR RULE OF THUMB FOR THE SIZE OF K PLANE NEEDED FOR A GIVEN SIZE BOAT? ITS A 88 MIRAGE INTIMIDATER 270, TWIN 330s WITH BRAVO ONES, ALSO WILL BE CHANGING TO ABOUT 1050 HP TOTAL IN SPRING, CURRENTLY HAVE BENNET TABS AND WELL I DONT THINK I HAVE TO SAY MUCH MORE ABOUT THEM, THANKS. NICK
88 MACH 1 11-20-2002 09:19 PM
Nick, somewhere I read that the size isn't that important. I run an 88 Mach 1 27' single 454 with a Bravo 1. My trim tabs are about 12"wide and 6 " long. Just need to touch the button and I'm running level and can bring the bow up and down with no problem. Later, 88
Dave M 11-21-2002 07:36 AM
If your tabs are too long on some twin engine boats, the drives can hit the tabs when turned.
formula31 11-21-2002 08:00 AM
I switched from large Bennetts to 280 k-planes on my 30 footer twin bbc bravo. While I had less tab effect at low speeds, I was able to run in the rough stuff much more level without getting beat as bad.
Biggus 11-21-2002 09:04 AM
The 280S K Planes would be the size that I would pick for your boat. My 280 Baja had these tabs and they worked perfectly.
Tbonepmp 11-21-2002 11:32 AM
I agree with Biggus, go with the 280-S K-Planes... They should do the trick for ya...
ROUGH WATER 11-21-2002 03:52 PM
thanks for the insight, how long and wide are the 280s kplanes? just wondering, thanks again, nick
ROUGH WATER 11-25-2002 02:27 PM
once again thanks for the info, could somone reply on the rough size of the 280 k plane, and you may piss yourself but i cant find where to buy k planes, help where, i see that eddies marine has a nice copy, but i just wanted to see the real thing first, thanks again nick
formula31 11-25-2002 02:54 PM
They are 19" long and 14" wide at the transom. They are not rectangular but have an area cut out on the insides for drice clearance. If you want a picture, let me know.
ROUGH WATER 11-25-2002 05:00 PM
yes close up pic please, here or [email protected] is fine thanks
