-   -   Exterior engine saltwater protection (https://www.offshoreonly.com/forums/general-q/373927-exterior-engine-saltwater-protection.html)
Mr. Demeanor 11-09-2021 07:20 PM
Moving a new to me boat from fresh to salt. Boat has closed cooling.
Motors are currently out. Considering coating oil pans with truck bediner. I've used the rattle can stuff on brackets etc in salt with great success. Also thinking about covering the lower half of the engines with Fluid Film.
Any ideas appreciated.
sailtexas186548 11-09-2021 08:31 PM
Bed liner… no way IMO water always gets under it unless it’s linex
good paint and keeping it clean w/ a corrosion x or similar spray works well
F14A water jet 11-10-2021 06:54 AM
This is what I am doing too.
https://cimg5.ibsrv.net/gimg/www.off...07a291bf3c.jpg
Mr. Demeanor 11-10-2021 11:08 AM
Ive used on parts submerged in salt for years with great results. Transom brackets, transom plates, trailer parts including axles, etc. LineX is tougher for abrasion but this wont see anything like that.
Xcomunic8d 11-22-2021 09:22 PM
Enamel paint. Clean parts real good. Put primer on it. Use high heat enamel. Put several coats on. I’m building an LS for salt water right now.
painted oil pan, block, front cover, rear cover, heads, valley plate, valve covers, exhaust manifolds, bell housing. In short if it was metal it got primed and painted.
aluminum gets this white oxide “rust” on it. Rust oleum makes a good aluminum primer in aerosol. And I’ve used various brands of enamel with good success. Just get a good bond to start with.
NOTE: I would not do anything to stainless.
smokediver 11-23-2021 06:30 AM
Just a decent paint should be sufficient. Excuse the mess in the bilge , just had changed the oil. Saltwater
https://cimg1.ibsrv.net/gimg/www.off...87406a14c.jpeg
