-   -   Mercury 383 mag stroker cooling system and RPM range (https://www.offshoreonly.com/forums/general-q/374289-mercury-383-mag-stroker-cooling-system-rpm-range.html)
CharlieWhiskey85 12-22-2021 11:28 AM
Looking at a boat out of town and trying glean some info. What does a newer 383 stroker have for a cooling system? Is it a closed or open system? I'm sure it's a dumb question but couldn't find a ton of info.
also, what's the preferred WOT RPM on these? Boat is currently running a 21 apollo and is running at 5200 wide open.
Picture of the motor from the ad:
https://cimg3.ibsrv.net/gimg/www.off...59aa1d81dc.png
tmmii 12-22-2021 11:35 AM
Looks like it is open cooling, I don’t see a heat exchanger.
Wally 12-22-2021 11:39 AM
Cooling systems go either way...all depends on the setup when installed. That pic is an open system...i don't see a heat exchanger anywhere in the pic for it to be a closed system.
RPM would be limited by the IGN system type...i believe most of the stock merc stuff limits it to 5400rpm max but that also drops depending on what prop you are running and what drive ratio...5000-5200 seems about right...
SB 12-22-2021 11:43 AM
See specs here:
https://samerwebapp01apncus01.azuree..._8m0080494.pdf
sutphen 30 12-22-2021 12:12 PM
its raw water cooled
CharlieWhiskey85 12-22-2021 01:06 PM
Ok great, thanks gang. Owner said he was getting his best speed at about 4900 but WOT was running 5200. Sounds like it's propped pretty well on paper then.
SabrToothSqrl 12-22-2021 01:48 PM
Ignition interrupt tells me it's an Alpha Drive... am I right?
CharlieWhiskey85 12-22-2021 02:27 PM
Bravo drive on an 88 Formula 242.
