-   -   Restore old mercruiser 454 mag carb (Italy) (https://www.offshoreonly.com/forums/general-q/375166-restore-old-mercruiser-454-mag-carb-italy.html)
MAS51 03-23-2022 05:51 AM
Hi Guys!
My name is Massimo, i'm write from Italy, I always read this forum with passion.
I'm restoring a very old 454 mag carb for a Italian speed rib (Focchi 730 kevlar hull)
I have a dream to have at least 500 horses (the rib is very very light, @ empty 800kg about)
so far I have proceeded with these parts:
Speed pro piston +0.30 and +22cc dome (bored engine block )
Steel connecting rods H Beam
ALL bushings new by jegs performance (cranckshaft, connecting rods and camshaft)
And Alluminium Head with 115 cc (chambre) and 320 cc. square port.
i think i do 9.5 compression ratio.
other transformation that I want to do is the replacement a flat hydraulic lifter with hydraulic roller lifter and relative Camshaft.
My question for you is :
which camshaft is suitable for this configuration?
which carbs is the best for this configuration?
I apologize for my bad english and put pictures of boat and motor on it.
https://cimg4.ibsrv.net/gimg/www.off...47941d52f3.jpg
https://cimg5.ibsrv.net/gimg/www.off...ccdc2064a0.jpg
Wally 03-23-2022 08:13 AM
That's gonna be crazy with 500hp! I like it! :D
here's the cam specs that SB posted a while back that i copied. this is for the stock mercruiser 500hp carb motor:
For Gen VI HP500's cam I have the following in my notes:
Merc HP500 Carb
Crane Gen VI#169611 Grind#HR-284-2S-10IG
Adv 284, 292 at .004” Lift with 1.7 .576 / .598
At .050” 222, 230
ICL 105, ECL 115
LSA 110
Part Number: 169611 Grind Number: HR-284-2S-10 IG
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1996 Up CHEVROLET 8 HYD. ROLLER WITH CAST IRON DISTRIBUTOR DRIVE GEAR
Engine Size Configuration
454-502 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 339 @Valve 576 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 352 @Valve 598
Rocker Arm Ratio 1.70
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 33.0 BTDC 71.0 ABDC 284 °
Exhaust 77.0 BBDC 35.0 ATDC 292 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99896
Loads Closed 150 LBS @ 1.900 or 1 29/32
Open 441 LBS @ 1.330
Recommended RPM range with matching components
Minimum RPM 2500
Maximum RPM 6000
Valve Float 6500
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 6.0 BTDC 36.0 ABDC 105 222 °
Exhaust 50.0 BBDC 0.0 BTDC 115 230 °
Remarks:
CRANE 16535-16 LONG TRAVEL HYDRAULIC ROLLER- LIFTERS MUST BE USED WITH GREATER THAN .570 LIFT CAMSHAFTS TO PREVENT ALIGNMENT BAR DISENGAGEMENT.
SB 03-23-2022 09:14 AM
Wally….That exact same HP500 motor, but with 454 msg short block was Mercruiser’s HP450. Yup, Merc offered it. Same carb, intake, heads, cam, exhaust….as the HP500.
MAS51 03-30-2022 03:26 AM
really thanks for the reply!!
what pressure / flow should I configure with these components?
Use of mechanical pump?
