-   -   CMI split tube clamps. (https://www.offshoreonly.com/forums/general-q/375399-cmi-split-tube-clamps.html)
tfarmer 04-11-2022 07:36 PM
Hello all, I have a question on my CMI Split Tube headers. I bought these used and needing to know what clamps I need when connecting the tails? I think someone one said they had a second design for them. They are 4.5 tails. Also where is the best place to order them. Thanks, Timmy
https://cimg8.ibsrv.net/gimg/www.off...9989a1469.jpeg
F-2 Speedy 04-11-2022 07:52 PM
Looks like a rope seal ? need a close up pic of the flange, could be v-band
Unlimited jd 04-11-2022 09:20 PM
Those are slip fit, no clamp. You put a bead of silicone around the header, then slide the tail over it. A bolt through the 2 brackets holds them together.
tfarmer 04-12-2022 07:41 PM
I'll get close up pics tomorrow. Just to make sure.
I'CE 04-13-2022 12:26 AM
This may just be what your in need of, for the split-tubes
Big Tube Rope Seal Clamp Assembly Kit - CP Performance
tfarmer 04-13-2022 06:21 PM
Yes that's the one's I'm thinking too. It looks like the tails could go together just a little more but that's as best I can get them.
https://cimg1.ibsrv.net/gimg/www.off...e9893d06f.jpeg
https://cimg4.ibsrv.net/gimg/www.off...e66d1b71e.jpeg
Unlimited jd 04-13-2022 07:32 PM
yep ice is correct. The first pics looked like they were similar to the stellings slip fit.
