-   -   500 EFI No beep/fuel pressure (https://www.offshoreonly.com/forums/general-q/375446-500-efi-no-beep-fuel-pressure.html)
splashandburn 04-17-2022 11:17 AM
I just replaced the wiring harnesses on both motors and now #2 does not beep and the fuel pump doesn't run when I turn the key. All the gauges on the dash work and the motor will crank when I turn the key. I have checked and jumped out the kill switch with no change. I swapped out both the relays near the ECM and checked that all grounds are attached. I don't know where else to look. Any help would be greatly appreciated
F-2 Speedy 04-17-2022 12:50 PM
https://cimg8.ibsrv.net/gimg/www.off...a6a12e0a90.jpg
find this should have a grey cap on it, check fuses............also check the 50 amp fuse on the starter that wire takes all the voltage to the engie/EFI
EDIT: and make sure the shifter is in neutral
splashandburn 04-17-2022 07:28 PM
i did check those three fuses and they are all good and I have checked that its in neutral. I don't think it would turn over if it was in gear. If that fuse on the starter were bad would it still turn over the motor?
F-2 Speedy 04-17-2022 08:35 PM
no my bad on the neutral crank issue...........you replaced the engine wiring harness only ?
splashandburn 04-17-2022 09:05 PM
yes and all battery cables to both motors. Basically new ground and positive cables.
