-   -   Bravo One in gear out of the water on hose.? (https://www.offshoreonly.com/forums/general-q/375475-bravo-one-gear-out-water-hose.html)
Mariah212Z 04-20-2022 08:19 AM
Is there any problem with turning in gear a Bravo One when running off a hose flush?
Is the fact that there is no water resistance against the prop a potential cause of damage due to spinning it free?
I was wondering if after a gear lube change , you could spin the gears for just a bit?
Just wondering...
F-2 Speedy 04-20-2022 08:24 AM
no problem shifting the drive while running on the hose, forward or reverse
Falcon 04-20-2022 10:42 AM
Should be fine without the prop and usually ok with the prop. Sometimes, the combination of a heavy prop can make it "chatter" at low rpm as the cone clutch engages/disengages rapidly.
Griff 04-20-2022 12:14 PM
Just give it about 5 seconds in neutral to let the prop stop spinning when shifting from forward to reverse or vice versa.
SabrToothSqrl 04-20-2022 01:10 PM
I verify FNR every spring on both drives on land before hauling it to the marina. Would much rather know at home something is broke, well before it's in the water.
