Bell Housing >
Bell Housing
Bell Housing
Old 04-23-2022 | 02:44 PM
Originally Posted by TomZ
Guessing it's Alpha-based if it started life as a 898 and using the same flywheel cover.
My thought is that it needs the 153-tooth (13 inch) flywheel vs the 168-tooth (14 inch). You will also need the appropriate starter to properly engage the flywheel (inline bolt pattern vs staggered).
Ayuh,..... The 898 came with the MC-1 drive, not the Alpha 1,....
Bondo is offline
Old 04-23-2022 | 04:23 PM
TomZ's Avatar
Same family basically. But yes. Should have said pre-alpha based.
TomZ is offline
