-   -   Newer Full hydraulic steering upgrade (https://www.offshoreonly.com/forums/general-q/375602-newer-full-hydraulic-steering-upgrade.html)
FORMULAfast 05-03-2022 11:17 AM
I'm working on 28' single engine V-bottom with a older version of hydraulic steering Hynautic is the name of it.
I have removed the entire system and replaced it with Latham Marine rams 2" bore 8" stroke and all new HP lines. I'm running a remote reservoir GM power steering pump and I'm looking for the information on how to select the right steering motor for 4 turns lock to lock. I believe the GM power steering pump is a 6.5 GPM speck and the lines are rated to 6000 PSI.
I just need to know a part number or how to get the right specs on what to look for.
Any information would be greatly appreciated thanks
PS Nobody at Latham is any help
Griff 05-03-2022 12:07 PM
Imco's chart on page 70 will get you close https://imcosteering.com/imco-catalog-2022-v5.pdf
jeffswav 05-03-2022 05:39 PM
You can go several ways with this. I found a local shop and had custom made lines, stainless hose and ends. They had a crimping machine to put on the ends.
FORMULAfast 05-04-2022 09:44 AM
I have already had the lines made I have the 2" bore 8" stroke rams all I need is a steering motor thats 4 turns lock to lock
Rookie 05-04-2022 01:20 PM
You have 25.13 in³ of fluid per cylinder. (π•r²•H) So, 50.26/4=12.565 you need a helm that is ~12.5 in³ per revolution. That is if your cylinders bottom out not you transom assemblies.
Griff 05-06-2022 12:27 AM
I assume you mean hydraulic helm when you say steering motor?? The chart I posted a link to gives enough info to get real close. Looks like you need either a 100cc or 125cc helm.
FORMULAfast 05-09-2022 10:43 AM
Yes I mean steering helm
Ok thank you for the information
