700sci fuel pump doesn’t turn off >
700sci fuel pump doesn?t turn off
Old 06-05-2022 | 02:38 PM
Default 700sci fuel pump doesn’t turn off
Hey guys,
on my 700s the fuel pump stays on even if ignition is off. The only way to turn off the fuel pump is to switch off the power through the battery switches.
Should I replace the whole pump or if I was to fix it where should I start..
‘Thank you
intimid8 is offline
Old 06-05-2022 | 02:48 PM
F-2 Speedy's Avatar
Ive never worked on a 700 but there should be a fuel pump relay mounted at the rear of the engine, maybe its stuck in the energized state
https://www.crowleymarine.com/mercur...s/13131_25.cfm
F-2 Speedy is offline
Is this a new issue? Relay stuck?
underpsi68 is offline
Old 06-05-2022 | 05:16 PM
Seen this a few times, twice was a bad ecm, once a bad harness
Unlimited jd is offline
