-   -   Pls look at pic of my drive gear magnets (https://www.offshoreonly.com/forums/general-q/376063-pls-look-pic-my-drive-gear-magnets.html)
Michaeloh59 06-15-2022 01:18 PM
Bravo XRs. What do yall think about the metal shavings?
https://cimg1.ibsrv.net/gimg/www.off...1bc1623d0.jpeg
https://cimg4.ibsrv.net/gimg/www.off...1b63e9f28.jpeg
snapmorgan 06-15-2022 01:24 PM
Time to open them up and take a look. Probably flaking off of the teeth
IGetWet 06-15-2022 03:41 PM
Have they been rebuilt recently? Any big pieces of metal on them? Are those plugs pictured from uppers or lowers?
ThisIsLivin 06-16-2022 07:52 AM
You have pieces not fuzz, you need to inspect your gears immediately. To get that kind of buildup, your teeth have flexed so much the hardened surface is coming off. Been there and it's not fun. I had my drive rebuilt several times by AADS and after break in you will see fuzz, You can rub it between your fingers and not feel any texture. I just pulled my magnets to change my oil last weekend and they actually came out clean after 2 seasons. I had my gears cryo'd during the last rebuild, I highly recommend it after seeing how clean my magnets are.
87MirageIntruder 06-16-2022 10:20 AM
Good advice being given here. You better have them looked at.
These came off a drive that was failing and had to be idled in.
https://cimg3.ibsrv.net/gimg/www.off...90ea1ec421.jpg
JaayTeee 06-16-2022 12:21 PM
I’d be betting you have gears that are looking like this
https://cimg9.ibsrv.net/gimg/www.off...70e7bf2e0.jpeg
Sydwayz 06-16-2022 12:39 PM
Cris-cross Apple Sauce.
It's just a matter of time before you turn your new fluid into chunky apple sauce. It's time to pull them apart and inspect for the parts that are failing.
Michaeloh59 06-16-2022 06:56 PM
Thanks Gents. Anyone have any suggestions as to a shop in the Houston-san antonio-austin area they could recommend?
Michaeloh59 06-16-2022 06:59 PM
i just bought the boat i dont think they have been rebuilt recently. Plugs are from the lowers. I’ll ask my tech about big pieces.
1MOSES1 06-16-2022 10:11 PM
Surprised people are giving opinions on plug readings without smearing the metal in your finger tips to see what you got. I’ve pulled plugs like that prior to our rebuilds…looked worse than it was. Would smear it in my fingers and it dissolved.
it’s hard to tell in pics while metal is all piled up. Just my 0.02.
