-   -   Vapor lock 525 EFI fix? (https://www.offshoreonly.com/forums/general-q/376605-vapor-lock-525-efi-fix.html)
Markd15668 08-03-2022 06:52 AM
Would replacing original fuel cooler unit on 2005 525 EFI's eliminate vapor lock? Annoying issue. OEM replacement part;8M0125854 - COOLER KIT-FUEL
Smitty275 08-03-2022 06:21 PM
Make sure you've got good fuel pressure. AND that it doesn't bleed off when you shut the engine off. Then make sure there's no obstruction in the cooler.
thirdchildhood 08-03-2022 08:33 PM
