Originally Posted by Twin O/B Sonic
(Post 4840759)
For idle tuning/set up, I back the trailer in at the ramp and leave the boat strapped to the trailer.
Way easier/safer than at dock. Done that a bunch of times if no other choice but on trailer is #1 pick. Also, the angle of the boat on the trailer at a ramp may not be the same as it is at rest in the water. More angle will change the fuel bowl levels. |
I’ll need to readjust the floats when I get her tied to the dock tomorrow morning. They were a little more raised on the trailer on land vs on the trailer at the ramp. Still some tweaking to do but getting there.
Impressive perseverance Tom!
Have you checked your rotor phasing?
Should have bought my Cig Tom!!!! Hahaha
Originally Posted by seafordguy
(Post 4842194)
Originally Posted by fbc25el
(Post 4842193)
I replaced batteries yesterday… found one to be a little weak so I’m thinking that may have been a contributor, too. |
I would pull the valve covers and run all the valves, and make sure nothing is binding or having some other issue. Maybe leak it down too. A few valves hanging even just a tiny bit will make you chase your tail
Saw the other thread, what solved your issue
Couple of things…
The carburetors were full of ethanol powder. Also, found that one of the meter blocks was missing the mail well plugs (really Barry Grant/Demon/Holley??). We also found that the batteries were a little weak. That may have caused issues with the ignition even though it was charging at 13.5-13.9 volts at idle. The port/#1 battery was the worse of the two (with the port engine acting the weirdest). The carburetor issue really was the biggest pain in the ass. They were a real mess. |
| All times are GMT -5. The time now is 03:40 PM. |
