Ready to kick this pos down the road… >
Ready to kick this pos down the road?
Old 08-07-2022 | 09:52 AM
TomZ's Avatar
Appreciate all the help guys.
TomZ is offline
Old 08-07-2022 | 09:57 AM
Sorry to hear about it! Is today better?
F14A water jet is offline
Old 08-07-2022 | 11:00 AM
TomZ's Avatar
I was really hoping for a successful test yesterday. Stuff happens. The title of this thread was the result of a number of frustrations all at once.
Today? Better. The weather is a little iffy today so I may not work on it today.
I’ll probably order modules for the distributors just to go ahead rule those out as issues. They’re from 1998 so I’m sure they’re due.
TomZ is offline
Old 08-07-2022 | 11:08 AM
Rookie's Avatar
I believe your idle circuit is too rich. I set my idle 13.7 and as much timing as I can. My new EFI setups needed me to up idle timing to 32° so it wouldn't stall during shift. I ran 2 different timing curves with those cams; locked 35° and 28°-36° High Idle on my Crane HI-6M's. I only netted 8° not the 10° it advertised, my light could have been off too.
Rookie is offline
Old 08-07-2022 | 12:23 PM
Originally Posted by Rookie
They are my cams that idled at 700 all day on my carb setups. I swapped them out when I went EFI. I believe timing was 28°-36°
do you know the specs?
as for the idle in gear,,its time to strap that boat to the dock and w/ a friend start trying different timing and idle screw adjustments till it goes in and out of gear.and like you said,,carb could be totally f-ed up.
sutphen 30 is offline
Old 08-07-2022 | 12:44 PM
TomZ's Avatar
I baselined the carbs and got idle down on the trailer but agree that it’s probably f-ed and needs tuning in gear. Agree that the way to do it is while strapped into a slip.
TomZ is offline
Old 08-07-2022 | 12:51 PM
Something I ran across when modifying the ecm bin files on my Camaro years ago, is that ign timing has a significant effect on WB02 readings. I agree, get a good timing light with adv capability and see what's up with the timing before condemning the carbs.
FWIW, my boat came with MSD marine ign. With the exception of the dist mechanical adv rusting and a box failure, its worked pretty well. The rusting was addressed by replacing the springs and spraying corrosion inhibitor on them. 5 years later, no more rust. Also carry a spare ign box now.
Edit: Mounting the MSD boxes to the boat as opposed to the eng, seems to make them last much longer. Don't think they like vibration.
zz28zz is offline
Old 08-07-2022 | 01:46 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
"Edit: Mounting the MSD boxes to the boat as opposed to the eng, seems to make them last much longer. Don't think they like vibration."Last edited by zz28zz; Today at 01:56 PM.
That's where mine was mounted for 15 years, away from engine heat and vibration. Still have the box and it still works fine. Treated the Pro Billet as well.
the deep is offline
Old 08-07-2022 | 07:10 PM
For idle tuning/set up, I back the trailer in at the ramp and leave the boat strapped to the trailer.
Way easier/safer than at dock.
Done that a bunch of times if no other choice but on trailer is #1 pick.
Twin O/B Sonic is offline
Old 08-07-2022 | 07:25 PM
seafordguy's Avatar
Tom - best money I ever spent was my Daytona Sensors ignition.
Hope you get it sorted while there is still some summer left
seafordguy is offline
