-   -   454 Distributor (https://www.offshoreonly.com/forums/general-q/376739-454-distributor.html)
Flmike 08-15-2022 05:44 PM
454 Distributor
I have a 96 454 330 hp will the Thunderbolt V distributor fit in a new GM 502 marine long block? I used the stock 454 dual plane manifold. When I Install the Distributor in the engine, the distributor won’t sit flush in intake manifold. It sits about 1/4” off the manifold and that is with the gasket on it. Am I missing something?/
SB 08-15-2022 06:12 PM
They use same distributor. You are probably not seated into the oil pump drive, which is just a slot in a shaft that mates with slot indide distributor gear. Turn dist upside down, look in gear, - see it ? Using a long bladed flat blade screwdriver, turn shaft just a c hair (that’s a measurement ) counterclockwise. Try dropping dist in again.
I f i didn’t make sense, search u tube for vids on installing distributor n small or big block chevy.
Flmike 08-16-2022 04:22 PM
Thanks for the help, that was it. Really appreciate the reply
GPM 08-16-2022 04:53 PM
You may want to make sure you are using the right gear for your cam
bajaman 08-16-2022 05:20 PM
was it a standard or red c hair? A bit of a difference...
