Anyone convert from carb to FI?
After burning through $400 in fuel the last time I was out, it got me thinking about FI. I'm running a 1050 Dominator now, so about the furthest thing from fuel efficient. I only have a 60'ish gallon tank, so it feels like I'm constantly running low on fuel.
Has anyone made the swap or have a comparison what to be expected from carb to FI? What are people running for aftermarket FI? In the car space a lot of people were running FAST, Holley, etc. If it's significant change in fuel efficiency a FI setup could damn near pay itself off over a few seasons. Not to mention the manners you get with FI. Thanks |
General rule is EFI is about 5-10% more efficient. It will of course depend on how dialed in the carb was vs the EFI tune.
Its HP to weight ratio = fuel burn
What boat, what motor? |
Significantly noticeable gas savings when I switched to Holley EFI.
If carb and FI are tuned to same AFR there are zero difference to fuel consumption. You can install AFR gauge in your boat and tune carb perfectly. I had Baja 29 OL with twin 600hp carb motors, holley 950’s. I tuned it 14.5AFR idle, 3000-4000rpm 13.2-12.8AFR, 4000-WOT 12.7-12.0. Four channel EGT gauge help tuning alot. Egt was in all situations below 700Celsius. It tell how rich you must go.
On average, an in-tune four-stroke gasoline engine will burn about 0.50 pounds of fuel per hour for each unit of horsepower. On a dyno chart theis fuel use would be under the BSFC (brake specific fuel consumption). Typical marine engine around .5 bsfc.
Unleaded gas weighs 6.1lbs per gallon 200hp x .5 bsfc= 100lbs/hr 100lbs/hr / 6.1 lbs/gal = 16.4 gal hr so 400hp uses 32.8 gal / hr 600 hp = 49.2 gal/hr |
Originally Posted by ksalmine
(Post 4846036)
Since most carburetors AREN'T "optimized" generally speaking a carbureted engine will be ~10% less fuel efficient overall than a fuel injected one. Of course we've all seen cases where the carb was really out of tune and had excessive fuel consumption, but that's a problem unto itself.
My personal experience comes from comparing my Baja 208 Islander to my 252 Islander; both with 454 engines, the 208 was a Quadrajet engine and the 252 a MPI engine. The 252 is ~1000 pounds heavier than my 208. The 208 had a 42 gallon tank, the 252 a 90 gallon tank. Based on historical fuel consumption-to-destination with both boats, running very similar speeds, the 252 actually gets slightly better "mileage" than the 208 did. It amazed me, frankly, to the point I was questioning the fuel gauge when I first got my 252. |
Has anyone attempted a lean cruise tune?
I’ve also seen some car guys do it. Apparently the exhaust valve gets hot. Also some Aussie cars were tuned like this from the factory. I think youd find your common cruising RPM and look at the map sensor to dial out like 5% fuel? Not sure how lean you could go. I’m still around 2/3 max fuel rate at my cruise RPMs. |
Originally Posted by hogie roll
(Post 4846045)
I’ve also seen some car guys do it. Apparently the exhaust valve gets hot. Also some Aussie cars were tuned like this from the factory. I think youd find your common cruising RPM and look at the map sensor to dial out like 5% fuel? Not sure how lean you could go. I’m still around 2/3 max fuel rate at my cruise RPMs. Boat motors don't equate to cars, as boat motors are always under heavy load,.... |
(Post 4846036)
Originally Posted by Bondo
(Post 4846057)
Ayuh,.... That'll guaranty burnt pistons, valves, 'n blown gaskets from detonation,.....
(Post 4846036)
I have my carb’s and others tuned in well.
I figure it's easier to save 30-50% or more in fuel costs by getting (voting) Uncle Pedophile and his cronies out of office. In fact will save that and more on everything else to. Political ? Yes ! Real info on subject ? Yes ! Fuel injection has it’s place. So don’t carbs. In general, not exceptions, what ever you or your engine tuner can tune best, is what is better. :) :wink |
After i replied to this thread about bbc intakes poor fuel distribution, i went for a ride and boom. Cyl 3 spark plug exploded. Luckily only at 3500rpm cruising speed. Hopefully it was caused by loose spark plug
https://cimg3.ibsrv.net/gimg/www.off...3e04ec28c9.jpg https://cimg5.ibsrv.net/gimg/www.off...45261e2003.jpg |
Wtf ? Damn.
Originally Posted by JaniH
(Post 4846071)
Fuel injection is nice with out a doubt. Do you save enough to justify the expense of conversion? I doubt it, but there are other reasons to go FI. I still say gasoline is the cheapest part of boat ownership. Enjoy!
I faced the decision on my NA 565 builds. I chose old school because that’s what I am and know. I have 2 circuit 1150’s that are crisp and Valako did a tremendous job not only with the porting but all burning very close. All plugs near identical. If your savvy with the FAST type systems go for it and I’m sure you’ll be happy but you’ll also have a bunch of time and money into it. Be easy to do the math on the fuel saved vs the cost of. Definitely not going to pay off for years.
JMO |
Originally Posted by Unlimited jd
(Post 4846075)
maybe it’s the angle of the pic, but that ground strap looks like it has rust on it. I’ve seen plugs come apart like that from water and detonation
| All times are GMT -5. The time now is 02:21 PM. |
