-   -   suck or blow? (https://www.offshoreonly.com/forums/general-q/377263-suck-blow.html)
ICDEDPPL 10-01-2022 05:12 PM
suck or blow?
I wanted to run cool fuel thru the pump but now i`m not sure the pumps are that good at sucking .
maybe it should be on the pressure side?
Thoughts ?
https://cimg3.ibsrv.net/gimg/www.off...8657ee11bd.jpg
Rookie 10-01-2022 06:11 PM
If the filter head is above the pump I see no issue pulling fuel through the cooler. I assume currently there is not an issue with the pump drawing through the filter.
ICDEDPPL 10-01-2022 11:48 PM
I`ve looked into this and those Pumps are gravity fed and don`t like to suck.
I`ll be changing that over to cool the return fuel.
hogie roll 10-02-2022 07:32 AM
Pumps in general don’t like to suck. Diaphragm style pumps can do it best. Gerotors can do it, but are sensitive to debris and the manufacturing tolerances. Centrifugal pumps can’t do it at all.
I would put anything that’s not a filter downstream.
SB 10-02-2022 07:57 AM
Least restriction possible to inlet of electric fuel pumps.
getrdunn 10-02-2022 05:20 PM
At this point in life I’d settle for either one! 😂
compedgemarine 10-02-2022 05:28 PM
suck, Mary Beth, blow means suck. not my joke but still funny.
