-   -   Kill switch (https://www.offshoreonly.com/forums/general-q/377358-kill-switch.html)
Smitty275 10-11-2022 05:23 PM
Kill switch
Boat is a '87 Baja Sport 220. The kill switch is not wired. Control box has yellow & yellow w/red stripe coming out the back that make the neutral start circuit. The kill switch has a purple and purple w/white stripe hanging off of it. Do I use these purple wires to interrupt the ignition "run" wire from the key switch? If not, how should they be wired?
TIA
SB 10-11-2022 06:01 PM
The purple wire right off the ignition switch (run/ignition position) for the ignition kill switch. Ie:lanyard kill switch.
Or are you referencing the neutral safety switch from shifter that uses the yellow/red from ignition switch start position.
SB 10-11-2022 06:15 PM
https://cimg9.ibsrv.net/gimg/www.off...3e9f3e712a.jpg
https://cimg9.ibsrv.net/gimg/www.off...88e2bf50e2.png
Smitty275 10-12-2022 03:05 PM
The purple ingition/run off the ignition key. That would be the one I'll need to interrupt with the two off the lanyard kill switch (in photo). Correct?
https://cimg4.ibsrv.net/gimg/www.off...ac5c206dbf.jpg
SB 10-12-2022 04:34 PM
Yes.
Smitty275 10-12-2022 05:09 PM
Easy enough. Thank you.
SB 10-12-2022 05:20 PM
Yup, just breaking the power from purple wire (which is ignition) when you leave the drivers seat unexpectedly.:( or keeping power there when driving :)
