A boats Bat gauge can be defective, hence the 13V. Bat should be 12.7 unless Bat charger was just turned off.
Might have corrosion problem or loose connection. As the boats running and doing ok then the connection gets worst so the sense lead starts reading less voltage so it increases output |
Originally Posted by liberator221
(Post 4849796)
Grounds all good?
I know on the automotive side of things, battery,frame, body,engine, a bad ground between these can cause an overcharge condition. Is your voltmeter right? 13v on a battery at rest? |
Originally Posted by AllDodge
(Post 4849800)
Originally Posted by SB
(Post 4849571)
I have gotten a bunch of alt's from DB, but they all have been the Delco marine style. No issues with those. Some are at 15+yrs old ? More ?
Anyway, subscribing to see more about these adj reg's and how it works out for you. :thumbs |
Originally Posted by zz28zz
(Post 4849856)
I measured 16.7V on SENSE terminal with eng at 3000 RPM using handheld meter.
Originally Posted by Rookie
(Post 4849893)
Just curious, will 16.7v hurt anything? I see on my EFI forums guys going with 16v systems.
Like your battery if a 12 volt battery. Light bulbs usually burn out quicker too. Will be brighter, though, until they burn out. Some electrical items like starters and fuel pumps will have better performance with no decrease in dependability. Ignition systems too. Anyway, make sure you know what something is rated for before throwing more volts at it. :thumbs |
No luck getting auto parts store to spin test my alternator. If they don't have the "make and model" they can't even turn their tester on.
Years ago I made a gas powered 12v batt charger from a 5hp eng and a 105A car alternator. Haven't run it in many years. Got it going yesterday and was able to spin test my alt. Runs right at 14.7V. Think this pretty much confirms I have a grounding issue as mentioned by liberator. |
(Post 4850604)
(Post 4850604)
Years ago I made a gas powered 12v batt charger from a 5hp eng and a 105A car alternator. Haven't run it in many years. Got it going yesterday and was able to spin test my alt. Runs right at 14.7V. Think this pretty much confirms I have a grounding issue as mentioned by liberator. Any local alt repair shops, which know about alt's |
Played around with it some more yesterday. Measured between alt gnd and batt neg post with eng running. Volt drop was very low (<0.1v). Connected a temp jumper wire across the same 2 points, but didn't help.
Moved jumper to connect alt output and pos batt post, it worked, for the most part. Max voltage now 15V at 3000 rpm. Made a real jumper with the correct terminals and some 10ga wire. Connected it to the alt output and where pos batt cable attaches to starter solenoid, no help at all. Back to 16.7V.. (BTW, there's no fuse at starter solenoid where alt output connects) This leaves the batt cable between the batt switch and starter, the batt switch itself and the pos batt cable from batt switch to batt. All 3 are working or I wouldn't be able to crank the engine. Still struggling to understand what's going on with this crazy thing. |
| All times are GMT -5. The time now is 01:24 PM. |
