-   -   700sci prelube after engine rebuild (https://www.offshoreonly.com/forums/general-q/377877-700sci-prelube-after-engine-rebuild.html)
intimid8 12-08-2022 05:59 AM
Hey guys,
would appreciate if anyone could assist me explaining to me the process of prelubing the engine after rebuild
i have built my preluber in house and would like to know where should I connect the hoses on the engine to run the oil through. If anyone has pictures would be of great help
thank you
87MirageIntruder 12-08-2022 09:59 AM
I used a home made pre luber I built from a hand pump, and pumped a couple quarts of oil into the return oil port towards the front of the engine. I could feel the pressure increase after the first quart.
https://cimg2.ibsrv.net/gimg/www.off...581bb76645.jpg
intimid8 12-08-2022 10:06 AM
Thanks so much for that…
your motor seems to be opened?
mine is sealed and ready to start! Would This be accessible given mine is fully dressed. Excuse me, I am no mechanic…
DrFeelgood 12-08-2022 10:10 AM
That port is outside the oil pan mounting rail. Should have a threaded plug in it. Accessible even on fully assembled motor.
intimid8 12-08-2022 10:29 AM
excellent. Thanks
do you know what fitting size is required
F-2 Speedy 12-08-2022 10:38 AM
I think there 1/4 npt
87MirageIntruder 12-09-2022 10:17 AM
That picture I posted is on a 496HO engine, and that one uses a 1/2" NPT fitting. I'm not sure what the 700 has, I know some of the earlier gen blocks had smaller NPT fittings.
Just be sure to use the more forward of the 2 fittings, use the one that doesn't have a plug in it in my picture.
