Help identifying 502 Magnum 8.2
Hi Guys!
New around here. Been directed from another board, where I am following the restoration of a 1997 Sunseeker Superhawk 48, equipped with 3 502 Magnum MPI 8.2 V8. |
First of all I would like to inform that I am a foreigner (from Madeira Island - Portugal), so I apologize for any mistakes in English.
I will do my best to keep a clear communication. I am restoring an almost wrecked Sunseeker Superhawk 48. I am having some trouble identifying the engine’s generation, specially because the serial numbers on the tags, don’t fit on Mercruiser’s range on the information around internet. I have been ordering already some engine parts, and I am becoming preoccupied because the first ones - valve seals - came all wrong, and more parts are about to arrive. From the beginning , I have been told those engines were Generation 6 and I have been ordering parts having this information as a reference. I am looking for your help but not sure If I already can post photos, but I will try.. well, it looks like I cannot post any photos yet… Let’s share some data: Only found two serial numbers tags: - K153852 - K152856 From what I have been searching, these numbers don’t fit on Mercruisers range for generation 5 nor 6… From the boat’s booklet, it says “3 x Mercruiser 502 MPI 445HP I have been told those were Gen. 6 but I have been starting to order some parts and became very preoccupied when the first valve seals arrived - been ordering them for gen 6 and they are much bigger than the originals… I don’t even want to think about the other parts I have ordered… hopping them to fit my engines because I already spend some money… |
Hello Alex.
Try adding a 0 in front of your serial numbers you posted. When I did that, it came up with a gen VI 502 engine. https://www.marineengine.com/parts/m...ts/sn/0k153852 In order to post pictures, you need to have a total of 10 posts on this site and you already have 3 Make 7 more short 1 word posts to reach 10 and then you can post pictures. |
Originally Posted by xlint89
(Post 4858771)
Hello Alex.
Try adding a 0 in front of your serial numbers you posted. When i did that, it came up with a gen VI 502 engine. In order to post pictures, you need to have a total of 10 posts on this site and you already have 3 Make 7 more short 1 word posts to reach 10 and then you can post pictures.. It worked on a suppliers website !! It came out as a Gen 6! Many thanks for your help! |
Now I believe the valve seals came wrong because of the supplier’s mistake.
I ordered them correctly, I assume! |
Engines when I pick them up:
https://cimg3.ibsrv.net/gimg/www.off...75acc730c.jpeg https://cimg8.ibsrv.net/gimg/www.off...dad0d4403.jpeg |
Serial numbers tags on blocks - only found two of them:
https://cimg5.ibsrv.net/gimg/www.off...7356bc928.jpeg https://cimg8.ibsrv.net/gimg/www.off...eaa6b76f5.jpeg |
Hell of a job!
https://cimg8.ibsrv.net/gimg/www.off...12a7e1f09.jpeg https://cimg0.ibsrv.net/gimg/www.off...fcf019735.jpeg https://cimg1.ibsrv.net/gimg/www.off...eeba15389.jpeg Now it rests on this shipyard under the island’s airport runway. https://cimg2.ibsrv.net/gimg/www.off...585e3314c.jpeg |
Working on it, to its original (almost) condition…
https://cimg2.ibsrv.net/gimg/www.off...8a5cff329.jpeg |
They are Gen VI engines.
Based on the serial numbers, they are the early cool fuel engines https://www.mercruiserparts.com/502-...502-v-8-1996-1 |
Originally Posted by Griff
(Post 4858790)
